How can I create deployment diagram on java web?
I've a java based website. I want to create deployment diagram on it. How can I create it? Please, show me the process as elaborately as possible.
Thanks
Thanks
You can download Edraw, software for creating UML Deployment Diagram from https://www.edrawsoft.com/uml-deployment.php and here you can find tutorials how to make deployment diagram https://www.visual-paradigm.com/support/documents/vpuserguide/
If you like you can download Java Modeling in UML 2.3 who has great features like generate Java class definitions from UML class diagrams, detailed documentation in HTML and RTF format, automatically synchronize model and code and etc.
Hope this will help you!
