Hi expert,
Whenever I fall in problem related to technology, I rush to you and get solved. Today I have come here to learn how can create encryption cell phone folder. I use galaxy tab. Do I need any software to do it?  What is the best software for it? If I need or don’t need, please tell me the process of encryption as I can learn it easily and keep data safely.
Thanks in advance
How can I create encryption cell phone folder?
Dear Fernando W Alvarez,
Thanks for choosing us again and again to get help.
Dear in Galaxy tab, it is possible to encrypt a folder or file. But you have to get a software for it.
In fact, there is no phone that provides direct encryption facility without any software.
Each time, we have to get an encryption software.
But i have a best plan for you to encrypt your folder or file.
You should use folder lock utility in this regard.
Folder lock will encrypt your folder and make it private. Only you can open the folder.
Other information and Download is available on this page, please click the link below.
Download + More Information.
I hope you will enjoy.
Thanks
