How can I create flash advertisement software easily?
Hi expert,
I want to create flash advertisement software. Is there any easy way to do it? I know it is not any easy work at all but I want to learn. Please, advise me and give me some instruction that will be helpful for me. It may be referring any good book or primary conception or anything else. I think you know better than me. So, what should I do if I want to create flash advertisement software?
Thanks
