How can I create joomla gallery with text site?
I would like to do a Joomla gallery with text for my daughter and replace the one I had previously designed before I learned about Joomla but I don’t know how to do it. How can you be of assistance?
Thanks dear for your idea. It is a very simple task to create joomla photo gallery with some text. The single thing you need is a plugin for this task. There are some types of plugin/module available on joomla site. Visit http://extensions.joomla.org/extensions/photos-a-images/galleries/content-photo-gallery and select one plugin you would like. You may try signplus for this from https://extensions.joomla.org/extensions/extension/photos-a-images/galleries/sigplus/ .
Hello, follow the steps to create a joomla gallery with text .
Joomla gallery has many good features. You can use text for the set of photo of your creation. You should set it for displaying within a set description.
Mostly plugin will help you to create a joomla gallery with text. CSS Gallery and very Simple Image Gallery are most effective.
