I need your help to create outlook alerts with SQL.
How can I do it as easily as possible?
Please, narrate it step by step as I can realize it easily.
Thanks in advance
How can I create outlook alerts with SQL?
If we are talking about the calendar appointment, here you must to:
1. Import the outlook reference.
2. As the reference to MS office Outlook object library.
3. Right click in the Project solution and then Add reference.
4. Click on the COM tab and scroll until you find MS outlook 12.0
Click ok and enter
Step 2 // Sets up and creates an outlook calendar entry
Outlook.Application outlookApp = new Outlook.Application(); // creates new outlook app
Outlook.AppointmentItem oAppointment = (Outlook.AppointmentItem)outlookApp.CreateItem(Outlook.OlItemType.olAppointmentItem); // creates a new appointment
Step 3 // Set appointment settings
oAppointment.Subject = "Enquiry Changes made to " + name + "'s enquiry"; // set the subject
oAppointment.Body = "This is where the appointment body of the appointment is written"; // set the body
oAppointment.Location = "Nicks Desk!"; // set the location
oAppointment.Start = Convert.ToDateTime(notesDate); // Set the start date
oAppointment.End = Convert.ToDateTime(notesDate); // End date
oAppointment.ReminderSet = true; // Set the reminder
oAppointment.ReminderMinutesBeforeStart = 15; // reminder time
oAppointment.Importance = Outlook.OlImportance.olImportanceHigh; // appointment importance
oAppointment.BusyStatus = Outlook.OlBusyStatus.olBusy;
Step 4 // save the appointment
oAppointment.Save();
After this appointment must be added to the calendar
Step 6 // send the details in email
Outlook.MailItem mailItem = oAppointment.ForwardAsVcal();
// email address to send to
mailItem.To = "mailto:[email protected]">[email protected];
// send
mailItem.Send();
And actually here it's finished.
