How Can I Create A Poster In Word?
I want to create a poster using theword and need to add the graphic and designs to the page and also make it look attractive. I want to create it on theword. How can I create a poster in word?
To create a poster in theword you have to know the features of aword that enable you to make designs and make your poster attractive. There is an option called page colour in the page layout tab that is used to change the colour of the page. Then you have the other option called word art that helps you insert text indifferent styles and formatting options. To add theimage you can have the image directly dragged and dropped on the page and adjusted by using the image properties options.
