How can i create a presentation on marks management system ?
I need to create a presentation using MMS or Marks Management System but I do not have any knowledge on using the program. Can someone please guide me on how to do it correctly.
You are looking for some information on marks management system. You are intending to make a PowerPoint presentation on the topic. Here I’m providing you some sites and PDF s that shall help you know more about the marks management system:
https://www.lakeheadu.ca/faculty-and-staff/departments/services/helpdesk
www.fig.net/pub/fig2012/papers/ts07l/TS07L_ha_5733.pdf
However, I’ve found this video also useful:
Hope these shall help you.
Hi Helly,
I have already understood your question. But I can’t decide the situation of your knowledge. However I will give you a clear guidance for solving your problem.
I think you want to learn more about MMS/ MARKS MANAGEMENT SYSTEM. Therefore please use below links and get some knowledge about that.
1. Slide share
As well as, you can watch a sample presentation by using the following links.
http://www.mms.oceanroad.info/PacsoftMMS10_files/v3_document.htm
Finally, you can watch the below video, which is explaining how can create a presentation you want will be pretty easy to understand.
Thanks
Notifications
