How can I create remote agent project plan?
I have installed Bamboo and made a project plan using default agent. Now I am creating a remote agent for another machine. How can I create remote agent project plan and run the project with remote agent.
Hi Hall,
Here is the process to create and run a remote agent project in Bamboo system:
This should solve your problem.
Hello!!
I have realized the matter of your problem. Now I am giving you the best solution regarding the issue.
Firstly you have to download the remote agent. Then the installation process will be begun. A directory should be created on agent machine which will be considered as a server.
From the main window of Bamboo select Admin. Then go to agents. Where you will see the agent lists. Then the ‘Enable Remote Agent Support ’ should be selected.
After setup the Remote agent can be used easily by command line.
Regards
Shifflett Laurel
Notifications
