Hi experts,
Can I create a simple webpage even though I have no knowledge about any web languages?
What software should I use or what are the online services that can help me create a website without coding?
Thanks experts.
Anshu
How can I create a website without coding?
Hi Emma,
You can always create simple webpages without coding.
Easiest way to create your website without coding is to use online services available.
You can always use Google Site or doodlekit to create your webpages.
The best part of this is that you can use it to work on your website on any computer with internet access.
Also,there are various WYSIWYG(what you see is what you get) HTML editors in which you can easily drag and drop the things that are commonly embedded in websites. For the basic design you can use Adobe muse.
There are some more WYSIWYG editors,for example
1. Adobe Dreamweaver
2. Amaya
3. EZ Generator
4. Kompozer
5. Alleycode
6. Seamonkey
I would suggest you to use Google Sites ,if you want to go with online services or you can use WYSIWYG editor Adobe muse with the basic design options for your webpage.
I hope this would help you.
points
Websites are now the best way to publicity worldwide. Through websites, you can share your thoughts and present yourself cool. But in order to build a website, you definitely need to code.
But it is troublesome and also time wasting to code page after page, typing and typing and bla bla bla. So developers has managed to produce such programs to allow you create your very own website without coding.
For this reason, you’ll need a good server to host your files. After purchasing a license, it’s time to setup a CMS which will allow you build your website very easily. CMS are coded to work with GUI implements and the code is generated automatically after your every change.
In this Techyv page, you’ll find out the most popular CMS programs to assist you. Everything is just made simple.
