plabon50
Posted on - 11/13/2013
How can i delete photos from my iPAD with iOS 7
I have my Albums synced to my computer so how can i delete the images/Photos/Videos from my iPAD but still have them in my computer intact and again dont have them synced back to my iPAD when deleted
IOS7 is a confusing for me but an awesome upgrade
Hello Plabon50,
An iPhone with OS 6, you can easily delete photos by, swiping to Settings > General > Usage > Photos and Camera, go to the camera roll entry and a delete button shows up. But It's not easy on IOS 7 as there might be some bugs. You cannot do it directly from your phone but by your mac pc. Now here is a quick guide about how to do this.
You need Image capture on your mac to delete your images from IOS device.
Exit the photos if it automatically launches
Open Image capture.
Choose the photos you want to delete.
Click the red button to remove it. That's all you need to do. And your synced photos will be fine.
But Apple still needs to resolve this issue as you can't delete them from your iPhone or iPad. In this
That's pretty simple:
Connect your device to your windows PC
In iTunes go to your device, make sure you are in library
Click on the 'Photos' tab
Choose the 'Selected Albums' and deselect the one you want to delete
Click 'Apply'
And you have deleted photos from device without option of being synched back again.
The primary view in the new Photos app in iOS 7 is actually now a unified view that collects all of the photos from your Camera Roll and Photo Stream, as well as any photos you’ve synced onto your device via iTunes. To delete the files completely from your Ipad you have to delete them both from the photostream and camera roll. Also disable the automatic sync from your Itunes on your computer.
