How can I delete some data in a SIM card?
Dear Guys, I hope you can teach me how to delete the files/ data saved in my BlackBerry Torch sim card. Would love to hear your reply. Thank you.
At first you need to open your phone book, then select your deleted files. It is easy to data off your SIM card as possible.
If your phone is capable to urge connected with the pc system then it might be far better to delete the content on your SIM card at a time. However if it's impractical I even have another plan by that you'll be able to take away all the items from your SIM card however not at constant time. I mean to mention you'll be able to use the mark all functions on your phone which is able to assist you to get rid of knowledge a lot of faster then removing it individually. You’ve got to try and do this issue for the messages likewise for the contacts that are possibly to own in bunch. Alternative things will not frustrate you to get rid of them even manually.
Notifications
