How can I display the full screen cover art of current song?
I need your help. I want to display the full screen cover art of current song on winamp. Is it possible? If yes, how can I do it? Please, tell me in detail about it.
Thanks
Thanks
Hi
First you should download Milkdrop2 plug-in for your winamp.
Then follow below steps.
1. Click on via tab
2. Then press F2 on the keyboard to toggle artist/song info display on screen.
3. Then press Ctrl + P > plugins>Visualization > select Milkdrop2 and Click “Configure”
When “configure” window appears click “Select fonts” and resize the fonts.
Thanks & Regards
Mckinney Ma
Hello
I found this solution but it seems only works with Bento skin. So change your skin to Bento and follow this steps:
Go to: Options -> Playlist -> and check Enlarge playlist and Show album art if playlist is enlarged boxes.
Now you are able to see your cover art in full screen mode.
