How can I display iPhone splash screen?
How can I display iPhone splash screen? I am having a hard time on exploring the features of this iPhone and I think I will need your help about how to display iPhone splash screen, can I set it to how many minutes would I love to make it display on the screen? And what is the default timer before it will not show up anymore. I hope you can share your experience with me.
Answered By 0 points N/A #175208
Dear Deborah,
You might find it hard to find applications which permits you to explore your iPhones directory and edit your iPhones splash screen. This is due to Apple's brilliant way of securing their iDevice. But if you really need to do it, then there is still hope and that is through Jailbreaking. Once Jailbroken, you can use these tools to access your iPhones internal directory:
Winscp:
i-Funbox:
iExplorer:
Also, when Jailbroken, you can install Apps through Cydia that support customization of your themes and even your splash screen.
