How can I do “Desktop Sharing”?
Is desktop sharing possible? What application can I use in desktop sharing? Please help me with this.
Desktop sharing is when a user allows others to see their desktop remotely even though they are not in the same room or area. It is usually use for online training, to help in fixing or troubleshooting computer issues, and even let the user connect to their own computer while away from home. This feature is free to download and there are several sites that you can register to. These are:
If you have a Windows Operating System, all you have to do is turn on the Remote Desktop Sharing by going through
Its really an easy method to share your desktop with another person as you like. And also you can solve some other problem occurring your shared desktop. Now i am explain it in some steps.
Step 1: First you have to download an application named "Team Viewer ".
Step 2: You can download it from the internet by searching on Google.
Or just follow the link.
Step 3: After completing your download you have to install the ".exe" file in your computer.
Step 4: Now you have to invite your friend to install the "Team Viewer" in his/her computer with whom you want to share your desktop.
Step 4: After completing your installation just open "Team Viewer" and you can see a window like this image as below.
Step 5: On the window you can see two fields, one is "Your ID" and other is "Password" these ID and Password are randomly created.
Step 6: Now you have to share these ID and Password with your friends as you want. Or you can know your friend's ID and Password. Now you type your friend's ID on the partner ID field and then press the "connect to partner".
Step 7: Now you can enjoy your partner desktop remotely.
Now enjoy.
Thanks and bye.
Notifications
