How can I download blackberry 10 sdk for Adobe AIR 3.1.1?
Hi expert,
I need your help. Whenever I face any problem, I come to you and get my problem solved. Keeping the previous experience in mind, I again come to learn some information. I need to download blackberry 10 sdk for Adobe AIR 3.1.1. But from where can I get it? Is it free of cost? Please, give me link as I can download it easily.
Best Answer by Ronald B Cline
Answered By 45 points N/A #139787
Hello there Sharon,
BlackBerry-10 SDK is what you need in order to build applications for your Adobe Air. You may download this SDK directly to the website of blackberry and yes it is free of cost so no worries. Go to this site: https://developer.blackberry.com/air/download/ and please do check first the system requirements needed in installing the sdk so that you would not face any problem.
Hope it helps you.
Roland
Answered By 5 points N/A #199369
BlackBerry 10 is the most recent and greatest OS for your BB devices. You can get the BlackBerry 10 SDK for Adobe AIR from the BlackBerry website or you can also download it from the link provided below:
http://www.softpedia.com/get/Programming/SDK-DDK/BlackBerry-10-SDK-for-Adobe-AIR.shtml#download
