How can I download dell mouse suite win7?
I need your help. Before some days I installed windows 7 and my dell mouse is not working because of not having its suite. So, I need the mouse suite for windows 7. How can I download the dell mouse suite win7? Is it free of cost? Please, tell me in detail as I can get it easily.
Thanks
Best Answer by Peter A May
Answered By 10 points N/A #148285
Hi Branddon Thomass,
After collecting all drivers on windows 7 then you should set up Windows 7 operating system. From my experience I can say that you can use the Vista driver for Windows 7 operating system. Now you can only get your driver from Dell’s official website. Just for your help I am giving a link where you will get a driver but I am not sure it will work. After researching I found that Vista driver will work in Windows 7.
Download link- http://www.dell.com/support/home/us/en/19/products/?app=drivers
Good luck
Answered By 0 points N/A #148286
Hello, I am also a user of Dell brand. You can get dell mouse suite win7 from Dell's official website. Actually, there is no updated version of this software for windows 7. You can use Vista compatible version which supports on windows 7. It's absolutely free from cost. You can easily download it from Dell's download center. Best of luck!
