Hi expert,
I have got a Lexmark printer but I can’t use it now because I have lost the CD provided with it. I use lexmark printer 2.4 version with my mac. How can I download the lexmark printer driver 2.4 for mac? Please, tell me in detail as I can get it easily.
Thanks
How can I download the lexmark printer driver software?
Hello Mr Abraham,
You can download driver for your Lexmark printer 2.4 from Apple's website. Or you can get it from another source. Also download the latest driver installer from the Lexmark's website. Lexmark drivers are also downloadable via Apple's Software Update utility.
Hope these drivers will make your Lexmark printer active. Best regards.
To install the Lexmark printer using the software from the internet, follow the steps below:
1. Go to the Lexmark website at https://www.lexmark.com/en_us.html. Click Drivers and Downloads
2. Choose the printer driver for your operating system which is 2.4
3. Run the installer you download and just follow the instructions on the screen.
You may also try to download the software here. You can find here different drivers you need that can be download for free.
