How can I download Netscape Navigator?
Hi there ,
Nice choice of selecting a Netscape navigator for browsing internet.
Ever since AOL stopped the overall development of Netscape navigator in 2008 the bad thing is that its not officially supported.
The features of Netscape navigator is that it provides better and efficient security solutions and added feature of spyware and also adware protection from most of the sites
Real time feeds through the Real simple syndication the RSS and can create different profiles and also can use multiple tabs at a time.
But i suggest not to download Netscape navigator , its outdated , not officially supported and can have many bugs .
I personally recommend using Google chrome it sure is the fastest , efficient and safe browser currently .
make sure you get latest one .
If you still want to know download Netscape navigator ,
Follow this link :- https://filehippo.com/download_netscape/
In order to install the Netscape Navigator you must have a site to log.
First you must go to yahoo.com and then type in the search a free download nets navigator which there are may subs that will appear. just click soft82 and it will automatic open and ready to download.
And if it is already downloaded click the image accept and you can now use the Netscape navigator.
