How can i download templates opencart gratis?
I am in need of certain templates but am unable to download templates opencart gratis from the net. Anyone with expertise will be of much help in this area.
Hello Denise,
You could use your normal browser to make downloads from the internet. But if you have a plug-in to do that job such that a software (download manager) makes the download then you'll have to make sure that the settings in your download manager is the same as the settings for your browser.
I suspect that's the problem here. Check the settings of your download manager and make corrections. You can download opencart templates from these sites:
https://www.templatemonster.com/
I hope this solves the problem.
