How Can I download Windows Media Player 64 bit Plugins?
I am a user of Windows 7. Now I want to download windows media player 64 bit plugins. Can anybody help me for download this. Please give me some suggestions.
Wassup Carl,
I believe I can be able to help you solve this query to the best of my ability. There are several windows media plugins for different software such as Firefox, Chrome and so, on. This is what you need to do to get the plugins;
If you require the Firefox plugin, go to the website.
Download the plugin and follow the prompts to install.
If you just require the general plugins, you may download the Windows media encoder. To get this, you will need to go to the website;Â and download the software for the plugins.
Follow the prompts to install and it should be okay.
I hope this solves your query.
You are looking for windows media player 64 bit plug-in, I recommended to you, You can download windows media player 64 bit plug-in from the official website of Microsoft. This is a product of Microsoft.
You can download windows media player 64 bit plug-in from the below mentioned link.
Click on the above links and you will find windows media player 64 bit plug-in.
First you need to validate your Windows OS, You are using a genuine version or not.
I wish this solution may be helpful.Â
Thanks!
Best,
Fenster Maxine
