How can I draw a dashed line in Microsoft Visio?
I can see "dotted line" report under "Organizational Chart Shapes" option but it is  coming with an arrow head which I do not want.
Please help me as I have to submit my report after an hour.
Answered By 0 points N/A #121505
Hi, Hope it can help..  ðŸ™‚
First open the Microsoft visio..
next to select line you want in a Microsoft visio, on the format menu click line and then select options you want.
line patterns appears select line patterns and then select one of the 23 available line patterns; including solid, dotted, dashed, and various mixed patterns.
PLEASE SEE THE PICTURE BELOW:
And if you want to edit the line select line weight.
In line weight select one of the six available line thicknesses, or click custom and in the custom line weight box, enter the custom line weight in points.
For example:  enter 18 pt. for a line thickness of a quarter inch.
And if your done click OK.
And if you want to see how it looks select preview box.
Good luck.
