Hi!
I have some documents in a PDF scan format and I would like to convert them to Word for further editing. I have tried a number of ways without any success, only being able to convert them to JPEG images. How can I convert PDF scan to Word? Thanks for your assistance.
How can I effectively convert PDF scan to Word?
Hello Gregory,
Here is how you can do effectively convert PDF to word.
If you do not have Adobe Acrobat you need to download it because it is one of the most convenient software for the conversion of PDF files to word. Especially when using the recently updated version. This link will help you download it http://get.adobe.com/fr/reader/otherversions/
– Browse and open then PDF file you want to convert by clicking on the ’’File’’ menu;
– Thereafter, click on save as.
– Select Microsoft word and further Word document to save your pdf as a word file.
Or you can do it online with http://www.pdftoword.org/. Very Easy, you just need to select the PDF file you want to convert then click on Convert. It’s all on the site.
