Jeremy Jack
30 points
Posted on - 10/20/2012
Hello experts,
How can I enable ITC processing?
I am using windows 7 64 bit operating system, dual core and 2.1 gigahertz processor speed. I just want to ask the process of enabling the ITC processing program.
I hope you can give me the exact information needed to get this done.
Thank you.
How can I enable itc processing?
Dear Jeremy Jack,
I will give you information to enable your ITC processing system. Here are some links about the ITC processing system for the Windows 7 operating system.
Best of luck.
Hi Jeremy,
Are you having HDMI?
It is real easy to enable ITC processing system in HDMI since you only have to go to < Graphics Setting > and find < Attributes > then you may choose < select > or < clear > ITC processing.
Hoping that the solution could be of help to you.
