How can I enable my OS option
Posted on - 02/07/2012
I have been running my server on Windows 2003 Server R 2 standard edition. Also, I have bought a system which runs with Windows XP and I need to add it to the current domain. I need help to activate my system to enable it use any OS in the server. Because the new system is making problem such as giving some RPC errors and authentication is not allowing etc. It can be solved by enabling the above specified option. So please help me to solve this issue. I will be thankful for all your help and support.
