I would like to have a 3des encryption algorithm with OpenSSL to make it secure. I have a Cisco 3745 which has been accessed unauthorizedly many times. How can I encrypt Cisco using 3des from command line? I'm using Windows 7 64 bit. Please help.
How can I encrypt using 3des from command line?
No configuration tasks are available that should be particular to the encryption hardware. There is a same procedure to configure both software-based and hardware-based encryption. There is a specific function in the system that detects automatically the existence of an encryption module at boot-up and utilizes it for the encryption of data. A software is used for the data encryption when there is no hardware to encrypt the data.
