How Can I Export Data From Outlook To Excel?
Hey everyone,
I have some tabular data on my MS Outlook. I want to edit that data without disturbing the Orientation and the Arrangement of data. How can I Export Data from Outlook to Excel?
Hey everyone,
You can Export Outlook data to MS Excel without any problem. You can have a look at these instructions.
1) Click on the “File” menu, and hover your mouse pointer on the “Open” option.
2) Select “Import.” This will open up a New Window.
3) Click on the “Export to a File” button, and then select “Next.”
4) Select Microsoft Excel in the options that are available.
5) Now, select the “Inbox” option, and click on “Next.”
6) Select the desired location for the Excel File.
7) Click on the “Finish” button. This will Export your Data to MS Excel.
