How Can I Export Lotus Notes To Outlook?
Hello all,
I have some data stored on the Lotus Notes. I want to export that data from Lotus Notes to MS Outlook. Someone, help me to Export Lotus Notes to Outlook.
Hello all,
You can export the data to MS Outlook using the following steps.
1) Open the Lotus Notes Application.
2) Click on the “Mail” option.
3) Select the “Export” option from the File Menu.
4) The Export Wizard will appear. Select the “Tabular Text” option for the Export option. MS Outlook supports these files.
5) Select the “Continue” option.
6) Click on the “Export” button to start the process.
After that, the data will move to MS Outlook.
Download NSF to PST Converter to export mailboxes from Lotus Notes to MS Outlook because this process can’t complete manually as Lotus Notes supports .nsf files while Outlook .pst format so first change Lotus Notes NSF files to Outlook PST format after that run MS Outlook and import resultant PST file successfully.
