How Can I Fill In A PDF Form- Steps To Follow.
For the school assignment, we have got a PDF file. That means I have to fill it using a computer rather than handwritten. How can I fill in a PDF form?
Step 1: Right click on the document.
Step 2: Click Hand tool or Select tool.
Step 3: As you move a pointer over a file, it will change to a different icon.
Step 4: Choose the Select option to type in the field.
Step 5: Press tab to move forward.
Step 6: Click on Submit button after finishing.
Uses:
1. Tab: It helps to type and to move to next field.
2. Up or left arrow: It helps in selecting the previous radio button.
3. Down or right arrow: It helps in going to the next radio button.
Notifications
