How can i filter noise directly from terminal using linux
Posted on - 01/24/2015
I have been using audacity to filter out noise from an audio file. Is there a way that i can run audacity on the terminal in such a way that i can easily integrate the noise filtering using a shell script i.e like an audacity command line version of audacity whereby i can just pass arguments and options
