How to find and delete unseen viruses on my pc
Sometimes in the directory folders I have some hidden viruses which I don't know of. They are too dangerous for my computer and basically I don't have any awareness about this matter. So please guide me about this and then how to use my system safely.
Just give me a complete and permanent method of finding & deleting viruses.
Best Answer by Kirk Valkyrie
Answered By 0 points N/A #119161
Actually, there is no way of finding viruses by doing it manually. I mean, searching it on your own, with your own ideas, without using any softwares for detecting Malwares. You cannot just point to a file or directory and assume that it is a virus.
Virus is detected by its signature. Virus signature can be a code of their programming, their behavior, how they attack, and so on. Antivirus softwares store these signatures and uses them to identify different types of viruses. Antivirus now a days has developed in much higher level of scanning and even uses different heuristic level of real time virus monitoring.
If you want your computer to be safe from viruses, install a very reliable Antivirus and don't just download stuff from the internet without knowing if its safe or not. There are bots which disguises as video files. But if you'll take a look on its size, its very small to play a video, somewhat like 4k. Be very cautious.
Do not use any illegal ways to manipulate software. They always comes with Trojan viruses. Purchase an Antivirus Premium or Pro version to use the whole features wherein you can easily detect and remove any viruses found. Try installing Deep Freeze software. It allows you to restore your computer from its original configuration when you restart it.
Answered By 75 points N/A #119162
Virus is one kind of a dangerous things of a computer. If you see the yellow file that means deep yellow file you can delete this or if you see any wrong file in your computer you can delete that.
If you think your PC has a lot of virus you can use the Kaspersky. It is one of the strong Antiviruses of the computers. If you upload that file you can use your computer beautifully, safely and cleanly or if you use Avast Antivirus you can secure your computer.
Answered By 0 points N/A #119163
Hi
There is another Techyv post which is also well described about this issue. So go that page and get more useful tips regarding on this issue.
Virus remnants on my PC
