How can I find Internet Trace to everquest servers using Ventrilo?
I want to find internet Trace to everquest servers using Ventrilo but I am new and I do not know how. Can anyone help to find the internet IP to everquest?
To run a trace command using Windows xp Follow these steps.
1. Click on Start.
2.Click on Run.
3.Type cmd in the Run Window.
4.In the command prompt window that opened type "tracert www.everquest.com" (Or Any Other Site).
5.Right click and copy the results. Paste them on Ventrilo and you should get the required information.
Thanks!
You can find the IP to ever quest by following these steps.
1.  Go to https://who.is/
2.  Type https://www.everquest.com/register and click search. Here you can find I.P address under Site Status.
3.  Login as server admin to Ventrilo server.
4.  Right click in voice chat box and then click on server admin->RCon.
5.  A command line box appears.
6.  Type status in command box and you will see list of users connected to server and their IP addresses.
7.  Search for IP address of the site which you found in step 2.
