Hallo there! How can I find Lotus Notes file transfer? I have several notes files that I would like to transfer online from one personal computer to another. Every time that I try to use the normal drag and drop for the individual files I realize that the procedure does not work. Kindly help me as soon as possible.
Hello Mr. Raymond,
In order to transfer your Lotus Notes from one machine to another you have to follow some procedures. Normal drag and drop will not work. Go here to see the step by step description on how to migrate your Lotus Notes from one PC to another.
Please make sure to fulfill the requirements before performing actions.
Hope this helps.
Best regards.
