kaspian
Posted on - 09/22/2011
I had a important email that I received about one year back but I cannot remember in what folder I kept it and do not remember the sender email address and title but domain name of the email I know.
Have any process that can be help me for finding and getting it?
Franksat
How can I find my lost email?
If you do not remember the sender address and the title of the E-mail of what you have to do, you have written that you remember the domain of the E-mail. So filter your inbox mail according to the domain of that email that you want to figure out it will select only those email which you received from the domain.
And then find out the mail that you want. But if you have deleted the mail that is very important for you then there is an option in your mail box which is called trash, you could find all the deleted mail in that and search for your mail in that folder.
If you did not find your E-mail in that folder as well then you can scan your inbox with E-mail recovery software that will recover all your mail and search for it in that. But recovery is very time consuming task. Thanks.
How do you access or check your email? Are you using webmail or email client, such as Outlook Express, Outlook 2007, Windows Mail? All these has email filtering options. Some are complete and some are limited in what to filter.
Email filtering helps you find the message easily because you know where it's saved and in what folder to look on. What's good about this is that you can activate and deactivate email filtering. You can use this feature when you needed the most.
No matter what software you are using, you can do search by filtering the folder, sort date and time, letters, sizes and others. It'll display the results according to what you want to displayed. Others use this all the time to sort out and arrange sender according to the sender, friend's list and relationship.
By doing this research, you can back-track and your memory remember what email address you are looking for.
