How can I find star dock with system tray?
Hi guys,
How can I find star dock with system tray? I want to see my star dock application in the lower right part of my computer system tray. It was not yet assigned to appear in my system tray, do you have any idea on how can I assign my star dock in my system tray?
Expecting some help, thank you.
Answered By 0 points N/A #175585
Open star dock and click object properties then select dock contents then check display system tray icon check box. otherwise add a new tab for system tray setting by selecting dock and then click my docks then create new tabbled dock option then select tabs and styles then click add tab button then click add system tray button it will show icon of star dock in system tray.
Hope these shall helps you
Thanks
