How Can I Fix A “504 Problem” In The Google Play Store?
I am facing a “504 problem” in the Google Play store. This problem is restricting me to download any application on my Android smartphone. How can I fix the problem?
Method 1
a. Open Settings.
b. Open Application manager/ Apps.
c. Find Google Play Store, and open it.
d. Clear data and clear cache.
e. Go back to Application manager/ Apps.
f. Find Google Service Framework, and open it.
g. Clear data and clear cache.
h. Try to download apps.
If the above method did not solve a “504 problem”, try this –
Method 2
a. Go to settings.
b. Open Accounts.
c. Open Google accounts.
d. Remove your account.
e. Restart your device.
f. Similarly, add your account.
g. Restart your device.
You can use a VPN if the above methods fail. Use your browser to download a free VPN on your device, and use it to download apps from the play store.
Notifications
