hillol
10 points
Posted on - 09/17/2011
Hey!
I need help to solve this problem. I have been using Vipre Antivirus from long time. I did not face any problem before. At present I see an error message on screen when I install VIPRE Antivirus software. I don’t understand what the problem is and how can I fix it? The error message is as follows.
"Error 1720. There is a problem with this Windows installer package.A script required for this install to complete could not be run.Contact your support personnel or package vendor. Custom action Upgrade_DetectExistingProduct script error -214702…"
Please help me.
Thank you.
How can i fix antivirus problem
Hey!
Please help me.
Thank you.
