How can I fix Illegal Operations?
If you tell me in more detail would be better but no problem I try to explain in vast way. Illegal operation can be done in various types of factors.
Copying a file or game from a dirty or scarce CD can cause illegal operation.
Program that has error or highly fragmented can case illegal operation or illegal operation can be done by virus or by malicious third party program, bad memory, bad incorrect or old video drivers, corrupt files, problem with windows file and many other reasons.
If you think you need more information then go to this site Click Here
Hi Lincon777,
Illegal operations are cause by many different factors or causes ranging from third part programs which may cause memory conflicting with the programs which attempt to run to data which is not read properly from the source this are just a few out of the many reasons. You did not mention your reason or which illegal operation you want to fix so I will try to answer you as general as possible.
If you receive illegal program because of third party program then usually the advise is to try to disable the programs that are running in the background to check if they are causing this error. If after disabling you do not get the error then you will know that it was the program and if the error is still there then reboot each program to see which one is conflicting.
If it is because of data that was not read from the source correctly then ensure the CDs you install are clean and if it is because of files then ensure you uninstall any files that cause conflicts.
Notifications
