How can I fix live wallpaper randomizer error?
I want to use live wallpaper randomizer but facing issue while running .exe file in windows 7. What are the basic recommendations to install it?
Hello mate,
Most of the time Windows Version of OS except XP are having trouble with installing the software. The reason being is that OS system wont work smoothly with software that doesn't have administrative permission. Hence, 99% of the time you need to run the software as administrator.
Here's what you can do.
1. Right click the installer and select Run as Administrator.
2. This should prompt you with a permission and click okay.
3. You should now be able to install the program smoothly.
Tips to avoid getting error when installing a software(unless its an XP Environment) and that is by Running as Administrator.
Hope this helps you solve the problem.
