Aaron Cast
Posted on - 07/02/2019
I am using a Samsung 4g handset from one year ago. But from few months my internet connection becomes poor. Therefore I am a university student and more of my work is done online and for this, I need proper internet connection through the day. So, how can I fix my internet connection?
How Can I Fix My Internet Connection
The Internet is a network system that is globally connected. Smartphones are now well established as the main way most of us connected to the internet. And it means getting the fastest possible internet speed on your mobile devices is more important than ever.
But sometimes this doesn’t happen you and have suffered from a lot of problem regarding internet connection in your mobile device, therefore, to speed up the internet speed on your 4G handset phone, you can do the following thing :
First, you install up performance-enhancing apps so, that you remove any clutter on your phone.
After that check your network setting and then make sure that you are on the best connection possible .then you remove the widgets and apps that are unnecessary running in the background. Now you install an ad – blocker then you restart your 4G handset phone, At last, you clear the cache on your phone.
After following the procedure mentioned above your internet connection on your 4Ghandset phone can easily be fixed.
