harmion
Posted on - 08/04/2011
 Hi techyv Experts ,
                                I have come here for a little issue to my Sony PSP device. I want to fix No volume on PSP device but I can not. It has been occurring since five days. When I play a song it remains cool for a while but after 5-10 minutes it shows that no volume on PSP.
I have checked the Automatic Volume limiter system but it was remained cool. I can not understand where the issue comes from. I have sought a hardware expert but he did not solve my issue. Any one can tell me how can I solve this issue?
rpm07
How can I Fix No volume Issue on PSP
If you are experiencing a no volume or volume problems in your Sony PSP. There are several factors that may contribute to the problem. Several factors is possible like a problem in the hardware,or as simple as a button accidentally left on while playing. I can suggest several solutions to your problem.
First, check the mute settings. Clear any current sound settings by pressing the audio button on the face of your PSP. Test to see if the problem is solved..
Second, disconnecting and reconnecting the memory stick will sometime do the trick. If the memory stick is not properly connected it can interfere with the volume on your Sony PSP.
Third, you can try  resetting the game system.Remove the batteries out first and just hold in the start button for five seconds while the battery is out then replace the battery and restart your PSP. Test your volume to see if it's been restored.
If none of the above methods fixes your problem, its maybe a hardware issue. Hardware issues can be corrected by a professional repairman( Sony Service Center ), while others cannot be fixed at all. If your system is still under warranty, consider exchanging it for a new one.
