How can I fix ntfs USB boot sector?
I am using windows 7 operating system. I have a problem with the USB boot sector which I use often.
I need to fix it immediately but I don't know how.
Can you assist?
Can you assist?
Hi!
Yes! I can assist you. By repairing or fixing the ntfs USB boot sector on your window. we use a fixmbr command that can seen in Recovery Console. your booth sector has a damage that corrupt due to a virus. I'll give you solution regards to your problem. Just follow step by step. it takes only 17 minutes or less than.
Heres how:
1. Enter the windows recovery console. When it reach the command., type the " fixmbr " and then press ok or enter.
2. The utility of fixmbr write a master boot record to the hard drive. It will repair any damage or corruption.
3. By taking out the Windows XP CD, just type the word " exit " and then press enter to restart your computer.
