hannahwtc
10 points
Posted on - 05/02/2013
Hi there!
I have SnowFlakes Chrome and it has been working very well. However, whenever I install a new plugin I realize that I get an error on the page simply saying 'snowflake error'. When I roll back to the theme without the plugin, everything just works fine. Which plugin SnowFlakes Chrome theme can I use without getting errors and or how can I fix this error?
How can I fix Plugin SnowFlakes Chrome errors?
Hi Hannahwtc,
Most of the problem encountered by Google chrome theme or extensions are cause by third party software conflicts and or malware.
You can solve most of these problems though by re-launching your Google chrome browser then restore from your last active session. If you still have the same problem after re-launch then you will have to try doing these simple steps by typing in about:conflicts in your address bar to know why your browser crashes.
As mentioned earlier, software conflicts and malware are most likely the cause of these errors. Try fixing this by running anti virus software on your computer system.
You can also try visiting this website and hopefully will help improve your computers performance.
Best of luck.
Snowflakes Chrome is a very outdated theme for Google Chrome. The theme simply too old to support new extensions and plug-ins. If you are alright with it, only installing plug-ins that were created before December 4, 2010 will work with this theme with a very few exceptions.
The best way around this problem is to simply choose more up to date themes rather than working your plug-ins around the theme. There are plenty of new themes that are available in Google Chrome and more is added each day. You can see the theme list here:
https://chrome.google.com/webstore/category/themes
Gibson
