How can I fix a problem with Samsung Galaxy Ace Web Skype?
Your Samsung Galaxy Ace and Samsung Galaxy S II run on the same Android version but Samsung Galaxy S II has a slightly newer version than the first one. The Samsung Galaxy Ace Smartphone runs on Android 2.3 Gingerbread while the Samsung Galaxy S II Smartphone is on Android 2.3.4 Gingerbread.
Samsung Galaxy S II pink
The Samsung Galaxy Ace can’t be upgraded to a much newer Android version but the Samsung Galaxy S II is upgradable to Android 4.1 Jelly Bean. Anyway, here are the specs of the new phone. The Samsung Galaxy S II is a 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies.
It was announced to the public on February 2011 and released on April 2011 measuring 125.3 x 66.1 x 8.5 millimeters and weighing 116 grams. It uses mini-SIM card and has Super AMOLED Plus capacitive touchscreen display with 16M colors at 480 x 800 pixels screen resolution. It supports multi-touch protected by Corning Gorilla Glass featuring TouchWiz UI 4.0.
It ships with either Android 2.3.4 Gingerbread or Android 4.0.4 Ice Cream Sandwich upgradable to Android 4.1 Jelly Bean powered by Exynos 4210 Dual chipset, 1.2 GHz Dual-Core Cortex-A9 processor, and Mali-400MP4 GPU. It supports microSD expandable up to 32 GB. It runs on 1 GB RAM with either 16 GB or 32 GB internal storage.
The primary camera supports 8 megapixels with f/2.6, 1/3.2″, LED flash, and autofocus featuring geo-tagging, face and smile detection, and touch focus. It supports 1080p video recording at 30 fps. The secondary camera supports 2 megapixels.
It has 3.5-millimeter jack featuring Active noise cancellation with dedicated mic; Wi-Fi 802.11 a/b/g/n with dual-band, Wi-Fi Direct, DLNA, and hotspot support; Bluetooth 3.0 with A2DP and aptX support; GPS with A-GPS support; stereo FM radio with RDS support; and microUSB 2.0 with MHL TV-out and USB Host support. It has built-in accelerometer, gyro, compass, and proximity sensors. The pre-installed web browser supports HTML with Adobe Flash support.
Java is supported via Java MIDP emulator. It runs on removable Li-Ion 1650 mAh battery with standby time up to 710 hours on 2G and 610 hours on 3G. Talk time is up to 18 hours 20 minutes on 2G and 8 hours 40 minutes on 3G. It is available in black, white, and pink colors.
1....
