I love to play guitar hero III android. Once I was playing, there was having a horrible sound and it got frozen. Then I turned it off and switched on the TV channel. But the next day, I found that the problem was still there. Again I turned it off, but next time the window was not turned on. How can I fix this problem?
How can I fix sound problem on guitar hero iii android ?
You can resolve this by updating your Guitar Hero III with the latest version available in the Play Store (Previously known as Android Market). The latest version available for the same is Guitar Hero III is 3.2.5 version. Also keep in mind that, free some built-in memory to perform the application smoothly. Hope this will resolve your problem.
Ccharle William
Hello there Jerold!
The problem may be game corruption. Remember that a game is ran by codes to make it work. Maybe some time when you were playing, the game itself snapped. Causing it to corrupting itself specifically the audio. What you can do is contact the developers and ask them directly about your problem. Or you may obtain a new copy of the game but first removing from your android. Cheers!
