How Can I Fix The Acctinfo 2 Dll Window 10 Error?
To solve this acctinfo 2 dll window 10 error, you will need to follow these steps:-
1) Extract the files that name “acctinfo2.dll.” from http://www.microsoft.com/en-us/download/details.aspx?id=17657 this file.
2. Now, Copy the file to C:\Windows\System32 and register it from the CMD with the entry “regsvr32.exe acctinfo2.dll”
3. Now, open up regedit, find for a reference to acctinfo2.dll, and copy the name of the key containing that reference to the clipboard
4. Now, open up adsiedit. msc as a Domain Admin and then go to Configuration, CN=Configuration…., CN=DisplaySpecifier…, CN=409.
5. Find an object “CN=user-Display” and open its properties.
6. Choose the Attribute “adminPropertyPages” and select the Edit option.
7. Inside the “Value to add” box, enter one number higher than the highest entry present inside it (i.e. if the max entry is 9, enter 10), followed by a comma, followed by the GUID you found in the registry.
8. Now, open up ADUC, use the “find” option to pick a user, and open up their properties. A new tab”Additional Account Info V2″ should be seen now.
