I didn't know what might have caused this error. An annoying message pops up from time to time and then hangs my machine afterwards, so I have to restart it. A lot of important documents got corrupted because it interferes every time I'm creating a new document or spreadsheet file. This is the error code:Â
Error_ipsec_default_qm_policy_not_foundÂ
How can I get rid of this error? What could be causing this in my system?
How Can I Fix this in Windows 7
The message Error_ipsec_default_qm_policy_not_found is due to Windows system file corruption which is due to a lot of reasons:
- An installation setup did not finish successfully.
- A file that was being erased did not finish the process.
- A software application might have been deleted improperly.
- The system may have a virus infection.
- The system did not shutdown properly.
To fix this error message, you can try a manual update:
- Turn on your computer.
- Sign in as the Administrator.
- Click on Start.
- Go to All Programs.
- Choose Accessories.
- Click on System Tools.
- Select Restore.
- Click on Restore my computer to an earlier date.
- Press on Next.
- Choose the latest restore point date.
- Click on Next.
- Confirm the process.
- Restart your computer.
If the above process is not workable, you may try to fix this automatically through User Fix:
- Download and open this (Error_ipsec_default_qm_policy_not_found) fix software program
- Install the software.
- Click on the Scan button.
- Choose Repair Errors.
