Hi expert,
I need your help. I am an animation maker. I make different kinds of animation software also. Very recent, I heard that anime studio pro 6 is a good software to make animation. Please, give your opinion and show me the way as I can get the mentioned software easily. Is it free of cost?
Thanks
How can I get the anime studio pro 6?
Dear user,
Anime Studio Pro 6 has great tools that are up to demands of a professional animator, but, still, there is not much difference between the Pro and Debut versions. You can always download it if you want to try it, its is not free of cost but has a 30 days trial offer. I will recommend you to download its latest version, that will be much useful for you.
Hope this will help you.
Thank you.
Hi Richard,
Hope you're doing good. Anime studio pro is a good alternative in creating a frame by frame detailing. You can try the latest version of Anime studio pro which is v9, instead of version 6.
It is not free, but you can download the 30-days free trial.
Here's the download link for this software,
Hope this will answer your question.
Thanks
