How can I get automatedqa testcomplete 9 ?
Hi expert,
I use automatedqa testcomplete 7. Now I want to use automatedqa testcomplete 9.
Though I know upgrade means something better, I’m not sure of it.
Does it differ much?
Should I use the version 9?
If yes, please tell me in detail as I can take decision about it.
Thanks
Answered By 50 points N/A #177521
TestComplete is a tool from SmartBear Software which used in automated Testing. Recorded tests as well as manually created scripted or keyword operations can be used to test different types of applications including Web, Java, Windows, HTML5, etc.
The new version 9 has many enhancements from its previous versions. The new version support all the browsers (including Google Chrome), Java7 supporting, better integration with Visual Studio, Silverlight5, RIA libraries.
TestComplete 9 includes small but valuable changes.
You can check a demo of the new features in the url.
