How can I get avast for android tablet?
I use an android tablet. I want to use avast in it. How can I get it? Which version is compatible with it? Please, tell me in details as I can use it.
Thanks
Thanks
Hello Samantha!
I suppose you want to download Avast Antivirus. Tablet, like the Samsung Galaxy Tab support Avast. Avast is free for download for Android mobile phones and your android tablet is the same thing, then you can download it for free too. The only thing you did not write is his name so I can't  verify compatibility now. Here is the link to download, very simple:
Hope I helped!
Thanks!
If you have an Android Smartphone and you want to try Avast antivirus, there should be no problem because the antivirus is available for Android devices. On your phone, download Avast Antivirus. Avast for Android is not only an antivirus but a cleaner and an app lock as well. It allows you to lock specific applications so only you can access them.
It also allows you to clean or remove junk files from your phone and improve the phone’s performance. Among its features include Wi-Fi speed test, Wi-Fi scanner, web shield, junk cleaner, RAM boost, charging screen, firewall (for rooted Android only), privacy permissions, Power Save, Photo Vault, anti-theft, call blocker, AppLock, and antivirus engine. With Photo Vault, it allows you to restrict access to your photos using a PIN code.
Once the photos are moved to the vault, they are hidden and encrypted. The Power Save feature allows you to lower down the phone’s battery consumption by adjusting set of settings like the Wi-Fi, Bluetooth, synchronization, and screen settings.
