Hi expert,
I need your help finding out my lost images from my PC. What is the best soft in this regard? I heard that easyrecovery Ontrack 6 works well. What is your opinion? Please, advise me as I can get back my lost images easily. How can I do it with easyrecovery Ontrack 6? Please, tell me in details.
Thanks in advance.
How can I get back my lost images with easyrecovery ontrack 6?
Hi there Jolene B Just,
EasyRecovery is a data recovery software, has an excellent recovery capability to search and recover more than 225 file types which includes images.Â
Has a Trial version. And the users have reported that it only shows files recovered, but you have to purchase the full version to recover the files which cost $400. Just install it and follow the on-screen instructions.Â
1. Open EasyRecovery.
2. Select Data Recovery from the left pane.
3. Select the type of recovery from the options. (Probably a deleted recovery will do, if not just try the other options).
3.1 DeletedRecovery – to recover deleted files on a partition or a medium, you can perform a quick scan, deep scan for thorough scanning but may take time.
3.2 FormatRecovery – to recover files from formatted or reinstalled partition.
3.4 AdvancedRecovery – to recover files from deleted partitions, infected by virus.
4. Select a path to save the files to be recovered.
5. Scan the selected drive or partition.
6. Select the files you want to recover.
Hope this will help you recover your files. Don't hesitate to ask for any clarifications.
Geeknerds is photo recovery software with free trial version. Like ontrack, it scans damaged and deleted photos. If there is a failure or deletion of storage media then the software still has 100% recovery function provided that the storage of media is not broken, destroyed or burned. Formatted images or lost images are the ones being scanned.
